Program TV2 on vip622?
Lets_Dance
20
I switched TVs in my room which is TV2 on the vip622 and can't get it to work. I think it was set to operate on channel 72, however, the TV only goes up to channel 69. How do I program it to operate on another channel?
The 622 does not output to a Channel 72.
- Air = 21 - 69
- Cable = 73 - 125
Chapter 12: See Page 101, last two paragraphs; and Page 102, Step 12.
NOTE:
If you are also running Cable TV, then you may want to check your TV for a switch and/or menu to see if it can be set from Antenna to Cable.
If the TV does a scan you could just see if it will find it. is it the only sdignal on tha tline or are you combining it with something else?
622 - how often to reset ?
Problems with IR Remote for VIP 622
