Quali-TV firmware
rrob311
941
16
New England
I did a master reset my Quali-TV receiver and now when I turn it on nothing happens. I have it hooked up through the component cables. Does anyone have firmware for this so I can try to load it? I reset the receiver because it was erratically naming channels that I was scanning in. I am not sure why it does this. Now it doesn't work at all and I haven't been able 'to find firmware anywhere.
above the red button is a "v-format" button. Press that a few times and you should get it back to NTSC mode
Cool, that worked. For some reason it was coming up with wack names for channels like Fox when I scanned the transponders. It was also losing the transponders I stored in the satellites. Hopefully this fixes it and it will be more normal.
if you go through the review I made you'll see the channel name wackiness is normal.....and no way to change the names
Captan Midnight
big Ku feedhorn ?
