Reuse Direct TV mounting?
gres
5
AZ
Hello all,
I've recently moved into a new home and it has a Direct TV dish with 4 coax cables running down to the basement to a switching station.
Now if I were to go with Dish Network could I use the existing mounts or at least the coax cables?
Perhaps the mounting location won't be ideal for the Dish Network but maybe a number of the coax cables to be reused. I just don't want holes put into my new foam roof (which was installed by foaming around the base of the dish mount)! I do have another roof section that could be used and so perhaps they could extend the cables?
PS didn't know what to search for if this was discussed previously so you can direct me
What does the dish look like?
Single 18" dish with 1 LNB?
22" dish with 3 LNB's?
larger dish with a line full of LNB's?
Are there any struts (braces) on the dish?
Reason I ask is the 18" & 22" dishes the mast could probably be reused but the larger dish uses a bigger mast. The cabling I **assume** can be used in some way or another depending on what the cables do once they come into the house. Do they go to a switch or just wallplates?
For what it's worth, I tried to have my Dish installer install on the same mount (the existing DirecTV dish is the same size), but he wouldn't touch it. Said it was technically not their property, and even though I had given them permission (since technically it's my property), the guy said no, and insisted on mounting his dish next to it on the roof. I even offered a tip but he says it's a legal thing and he could get in trouble if his boss were to audit the installation and see that the mount is old.
It's done everyday. Most Dish polars will fit right on there. As Ice mentioned above,some larger dishes would require larger masts with struts for added support. The cabling should be reusable, if it is undamaged RG-6. Satco's will sometimes ask for their LNB back, but I've never heard of them asking a cust. to dismount a dish. The existing mast should be checked for plumb, and the mounting bolts should be up to par. If your tech is concerned about Direct wanting their mast, he can leave the one that comes with your new dish. That way, they get a compatible mast without having to take one down.
I don't know where you are located, but in my neck of the woods, we reuse the mast if possible without any fears of failing QAS. As far as I know it isn't a fail.
Now, if your getting a 1000.4 dish, then you can't use existing mast's. The .4 mast is a thicker guage steel and normal mast are not up to snuff. Also, larger direct mast have too big of a diameter unless you use a pipe adapter. Fine for 500 or 1000.2 dishs', but a no no for 500+ or 1000.4.
It is a 22" dish with 3 LNBs
Thanks for the responses.
ok so the Phase III uses a stock 1 5/8 mast
since you are in arizona Dish would give you a Dish 1000.2 which is for HD and they can use the same mast
it can be done no problem, even with a larger directv dish, installer just has to use a quick pipe, i do it all the time
edit- as long as the current directv mast is on securely and there is line of site. i had an install where the directv mast was so poorly placed i had to put another mast next to it
That is a failed QA in my DMA Using a quick pipe is unapproved. But, i just have the costumer sign off saying he wanted me to use it..
Sat 119 No Even Number Transponders
little help....please.
