Sat 129 signal
Nope.
I put the dish pointer app on the dish today and it doesn't look like it. I'll do it again in the am and snap a picture.
Posted Via The SatelliteGuys Reader App!
Yep unlikely if the other sats haven't moved and 129 has then something is growing or has moved into the path. If the others are semi effected but not as much as 129 it could be that the reflector got bent. Best way to tell is to take the reflector off and lay it on a flat surface if it kinda wobbles around its been bent, if it just lays down flat around the edges then it should be fine.
But based on that pic it looks like the trees to the right could very well be a problem for 129. 110 is looking like it's running out of room as well...
two Hoppers and one joey
