use this analog meter w/SWMline3 dish?
Yes, it will work, but you will also need a part called ASL-1, or a single power pass 2 way splitter, along with the power supply for the SWM LNB. The ASL-1 looks like a 4 way splitter. It allows you to use a standard analog meter to peak 101 (and 119 for a SWM5 LNB). There is an input for the power supply on the ASL-1. If you are using the single power pass splitter, the power supply is connected to the power passing port. Do not connect receiver itself to SWM LNB until aimed.
The B-band converter is not used with SWM technology.
Pixellation problems 95W - DTV36EDS Zinwell WB68 switch
on SWM 3LNB, need D* splitter for only one TV?
