Using your computer monitor as a TV?
Fgsilva
803
Vallejo, CA
Hi,
We need a TV for our boat and we're trying to go cheap. We currently have an extra computer monitor and I was wondering if anybody knows if there's an adapter that you can use to connect directly from a dish network receiver, for example, to the back of the monitor.
Thanks!
After reading your post I pluged my VGA monitor into the RGB jack on the back of my DN 6000 HD receiver and got a big fat nothing. I knew it wouldn't work, but since they "fit" I would give it a try. In the menus on my monitor there are different choices listed under RGB. Color 1, Color 2 & Color 3. When I get some time later today I will mess around with it. I still think it won't work. I found this online.
http://www.svideo.com/video2vga.html
I assume you want to convert your composite (yellow) sat. output to VGA.
LM
The 6000 HD will work fine with a VGA computer monitor, but you have to change the setup on the 6000 to activate the RGB/VGA output. The component and RGB outputs are not active at the same time. You have to select one of the other.
Does HDMI always mean HDCP Compliant?
Help needed on small HDTV decision
