What cables or converters does 942 come with?
kluken
326
7
I am getting a 942 to replace my 921. I use DVI today, I know the 942 is HDMI. Do I have to replace my cable or does the 942 come with a cable or converter. My current DVI length is about 9-10 feet.
birddoggy said:
it comes with a HDMI to DVI cable, and then a DVI to HDMI adapter (if i remember right)
That's what mine came with. So, you should be all set whether you have DVI or HDMI.
BobaBird said:
You may not be all set if you have HDMI and want to receive sound through that connection. For that you will need an HDMI-HDMI cable.
I am using the HDMI=>DVI cable with the DVI=>HDMI converter (all came with the 942) to give a HDMI-to-HDMI connection and it works fine, sound and all.
da Doug
Thanks! I already have a DVI cable for the 921, so the adapter witht he 942 shoudl do the trick. Any idea how long the HDMI->DVI cable is? I need about 9 feet and I can us the native cable otherwise the adapter will have to do.
Which SW Is On Your 501/08/10?
942 problem with autotune function
