there is a $5 fee for the 322 if it is not connected to a phone line
Nearly 10,000 posts and thats all you can come up with?
Why is there no $5 fee for a 322 if it is connected to a phone line? How does dish benefit from this?
If you really want to pay E* $5 more dollars just disconnect your phone line, they will be more than happy to add it to your bill
That is only a little more than a 1/2 post each month.Only 25 posts and you think you can call him out like that???![]()
I agree with you, but Dish has never moved very fast with anything - which is actually good with the courts.It very much seems like it should be the opposite. Force the phone line on the 311's so they can see that they are located at the same house and not worry about the 322 since it has to be at the same house.
That is only a little more than a 1/2 post each month.![]()
I agree with you, but Dish has never moved very fast with anything - which is actually good with the courts.![]()
However, I think they are just slowly laying the ground work for the future, which will then require the receivers to be physically connected to each other either by the same phone wiring or the in house electrical wires.
This will require you to run a phone cable across the street to your neighbors; or maybe an extension cord if using the electrical service, since the power transformer would isolate the signal.![]()
DISH benefits because it shows that all of the receivers on the account are at a single physical address.
2. Caller ID would be needed at dish and many people have that blocked.
Caller ID is not blocked on a call to a 800 number. Even if you try to block it.
