Who Has Better HD PQ Today - Dish or DirecTV?
rtperryal1
Jan 26, 2006
24
I have not had a chance to check as of late. I will as soon as I can and will report back:up
Thanks, msmith198025...I look forward to your report.
Thanks, to the others who responded to my question. I have a 622 and live in the southeast. I've never had any drop-outs or signal strength problems, but I've heard some areas of the country benefit more from Ciel 2 than others.
Mike D-C05, I like the idea of the 722k with 2 OTA tuners and am thinking of getting it to replace my 622. So, I'm interested in hearing what you think of the PQ of the 722k. One question: There is only one coaxial imput for the OTA. So is the signal split and thus the PQ decreased if using both OTA tuners at the same time?
Thanks.
ehren
1,440
Wisconsin
How many MPEG 4 channels per TP does Directv do?
Dish does 7 (UGHHHHHHHHHHHHHHH) and the FSN-HD's have never looked worse.
If Dish cut down to 4 maybe they would care about quality? Sure can't wait till they try and squeeze 8! Boy oh Boy! :rolleyes:
HDRoberts
4,795
31
Cleveland, OH
DirecTV does 5, but that is on a Ka transponder, which is sliced up a bit different, and has higher FEC requirements. So it's not an apples-to-apples comparison.
Carl B
920
Arvada, CO
The Denver locals were among the first channels to be put on Ciel 2 and are on spot beams. I noticed improved PQ on these channels after the transfer. This morning I did a detailed comparison of their PQ versus my OTA version of the same channel and I can say that Dish's PQ on those channels has definitely improved. Color saturation and contrast have greatly improved on those channels via Dish and there is little or no difference in PQ between them and their OTA counterparts.
I've also noticed that my Starz and Cinemax HD channels seem to have better color saturation and contrast now that they are on Ciel 2, but I didn't make any actual comparisons with those channels.
MikeD-C05
33,315
31,819
Nederland , Texas
Thanks.
One coax that splits inside the receiver into two ota tuners. There should be no decreased pq on the ota. I have the Echostar Pal plus dvr for ota and it works on the same concept and I see no difference between the two ota channels in regard to pq and I can record two ota at the same time. With the 722k you can use the two ota tuners in two ways: In Dual mode tv 1 gets one sat and one ota, tv2 gets one sat and one ota. In Single mode & I 'm only guessing since I don't have one yet, that you can swap between either ota or sat or both ,using pip. But I will let you know what I think of the pq , once I get it hooked up this week. I'll report back then.
another remote code
Slingplayer on Linux!
