LocutusOfBorg
Free speech is more important than your feelings
If you're looking for something to run an actuator you want a G-Box from Sadoun. It uses diseqc 1.2 to move the dish.
The G3000 doesn't do the actual moving, the HH or actuator does that.
I see no reason why the Gbox couldn't work with a 12'. The box just counts.
Am I wrong here?
How can you tell that the receiver tells it to stop?It has a tendency to keep moving the actuator after the receiver tells it to stop.
Did you manually drive and Lock each Sat and save it's position to the VBox?I assumed that the receiver gets data back from the Vbox and then the receiver tells the Vbox to stop moving the dish.
When you store the position, make note of the Position Number and Pulse count for 2 Sats
Then go back and forth between those Sats and see if it stops at the save Position Number and Pulse Count.
When you save the Position, does the VBox display flash a couple of times?It goes past the stored values.
