Have a question concerning this dish. Would you buy this one with its low price or a 1.2m for Ku band use?
i got this dish just for Ku band... I like actuators much more than the little ku motors
Forgive my ignorance but, I am a bit confused. I have now built my dish and actuator arm and assembly. I did place the ACTUATOR arm on the LEFT side as stated in one of the posts due to me living in Florida now for the DUMB question. I cant figure out how the dish will move from left to right and vice versa once the actuator extends and retracts. IT seems to me if the UP RING (3) is attached to the dish and everything else is bolted and tightened securely along with (25) the polar mount pipe, where does the dish pivot or rotate??? HELP
Rodm
When it comes to connecting/wiring the Sensor-, sensor+ section of the Sathawk GBOX to the PMA24 actuator's two sensor terminals, which are not marked +, or -, does it makes a difference how they are connected.
Does it affects the operation of the PMA24 actuator, or could it damage the reed of the actuator, if it is not wired correctly. Wiring the motor section is no problem, I am conserned with the sensor part of the actuator. Where does the sensor + and - of the GBOX connects in relation to the actuator sensor terminals.
Any information is greatly appreciated.
Thank You
avenger.
Makes no difference on polarity of sensor wires.With the motor its trial and error!if the motor wires are backwards then the motor will just turn the wrong way.reverse wires to make motor go right way.
too bad I already have 3 6 footers![]()
