Q re DISH Network hard drive format / drive swapping
KAB
21,742
5,230
Fishers, IN
So, after all the "synergy" about this topic...one word conclusion...
Paperweight!
Reactions: ChadT41
TheForce
39,052
15,082
Jacksonville, FL, Earth
related question- if a hard drive fails in a VIP722K, can one purchase a new same size hard drive and stick it in as a replacement and it will auto format and prepare the drive or does the drive need to be formatted by some factory system. I don't have a problem, yet, but would like to know if that day comes. TIA.
TheForce
39,052
15,082
So, if I replace a 500Gb Western Digital drive with the exact same model and size it will format the drive and be good to go but if I replace the WD with a Seagate model it will not. Correct? Just trying to learn the limitations if the day comes and I need to do a repair.
Is there a list of drives that will work as alternates?
Hall
18,409
3,199
Germantown OH
...but if I replace the WD with a Seagate model it will not. Correct?
Certain Seagate models might work. I haven't seen, nor looked, for a listing for newer DVR models. I know they exist for much older DVRs though. Search Yahoo! Groups for "dish dvr" or "dish mod" and see if they have more current info.
Also, if I'm not mistaken, the drive models that Dish and other DVR makers use aren't your off-the-shelf WD, Seagate, etc models. They're usually DVR-tailored models and not necessarily ones you can buy at Newegg, etc. They can be found, but just not from the usual places.
Reactions: TheKrell
TheForce
39,052
15,082
Thanks for the info. I've never pulled the cover off to see what was in there.
When my first 722K lost the HD after a year, I just called for Dish to replace it and the tech came out and swapped it out. Then he decided to go on his own and begin to install a new Dish which wasn't part of my request. I own all my dishes, all three of them. I saw him digging a hole in my front yard when I stopped him. My dishes are all out of sight on the roof. After a few words and me saying I was going to call Dish and complain he packed up and left. This sort of nonsense irritates me which is why I felt next time it may be easier to just do the repair myself. On my other 722, Dish just sent me a new one with a label to send the old one back. I don't know what triggers an install for a replacement repair but I understand if a Hopper upgrade is requested the home wiring may need to be redone.
Reactions: TheKrell
TheKrell
A mighty and noble race originating on Altair IV.
38,842
46,557
Fairfax, VA
Unless you own your DVR, there isn't much point to replacing the drive yourself. Just get the whole thing replaced.
I own my 722, but I had Dish replace it anyhow when it failed. (It wasn't the disk...) My refurbished 722 also shows "Owned", so I'm happy.
TheForce
39,052
15,082
The last DVR I bought was a 921 and when they obsoleted that on me I said never again. Just rent the damn thing. I suspect the days of +$100 a month for the few channels I watch will be gone and Dish will have to readjust their business model. Times are changing and IPTV will soon make what Dish supplies prohibitively expensive. Look for DirecTV to really change things soon now that they are owned by AT&T. Dish Network is the remaining independent satellite service left and from what I see my most expensive programming time. If money ever gets tight around here, Dish Network will be on the chopping block, replaced with IP channels and OTA, TIVO.
navychop
60,079
27,394
Northern VA
I always figure I could drop to the Welcome pack and spend a year watching what's on EHDs.
harshness
18,899
4,066
Salem, OR
Given how paltry AT&T's hardwire footprint is, DIRECTV isn't much better positioned than DISH. As it is, AT&T is busily trying to come up with a receiver that will serve both DBS and terrestrial installations and I would imagine that won't come quickly.
While AT&T has made a mountain of promises about expanding broadband service, much of it is likely to be wireless and that's not going to get it for TV customers.
Reactions: TheKrell
