4K Playback issue on Hopper 3
JSheridan
8,899
10,028
USA
Start a regular show downloading then try the 4K show so it is number 2 in the que
This worked on my 16/.8 Dsl
Thanks for the tip. Just tried it and it still says Insufficient Bandwidth and won't let it download.
JM42
1,748
280
GA
I have no doubt it doesn't work because even with 50/5 it takes awhile before you can watch it.
Yeah, Dish has some issues on download speed.
What ISP?
Either Dish is throttling and needs to work on their bandwidth management techniques, or the ISP is throttling.
I did some testing. Normally my Dish subnet is bandwidth limited to 16mpbs. Even when I gave it a full 75mbps, there are still issues. Download speed seems to max out in the 10-20mbps range, usually around 12mbps, HD or 4K. I'm on Comcast now, but saw the same throttling under ATT.
lparsons21
9,925
8,073
Herrin, IL 62948
50/5 Time Warner Cable
Which should be more than enough for a live stream, but even on my 100/10 I can't do a live stream of 4K from Dish though I can from YouTube, Amazon and Netflix just fine. And some of YouTube is 60fps too!
IOW the problem isn't at your end...
Sent from my iPad Pro using Tapatalk
gjolsen
41
5
New Hampshire
Yeah, there shouldn't be a problem. As long as you have a high speed hdmi cable you shouldn't have a problem. Non high speed cables have been obsolete for almost 10 years now, so that's honestly likely not the issue. It's hard to find those old, slow cables now.
Maybe try another 4K program? Make sure your hdmi cable is tight to both inputs, check settings. Plugin reset the hopper and tv. If problem persists, I'd try swapping cables or inputs in case of possible defective cable or hdmi input. I don't think that's likely because I don't think you would get a picture at all in that case. If all this fails, either the TV or Hopper 3 is likely defective and it's a matter of finding out which. The likely problem would be the Hdcp 2.2 protection failing on one end or the other.
Swapped out the HDMI cable with a brand new one. Everything works now in regards to viewing 4K content on the Hopper 3.
Thanks to everyone for your feedback - always helpful.
gjolsen
41
5
New Hampshire
Reactions: Scott Greczkowski
budda
596
100
Oconomowoc
I tried a 4k show that was free. On a 4k joey hooked up to a 4K tv. Picture was nice but was not stunning. Picture just does not pop. I have 60 Download 5 upload. A little disappointed with the quality. The show was Suits.
drwatson618
512
204
I've tried replacing my HDMI cables and still can't view 4K on demeans. I have 200 down and 20 up and get the insufficient message. I wonder if I should try replacing my Ethernet cable.
vipul128
93
28
Just purchased a 4K TV and I'm trying to watch some Olympics on demand but I'm getting the same insufficient bandwidth message as others. I have a 60/5 connection and have no issues streaming Netflix, Youtube, Amazon 4K but for some reason I can't get Dish to download the 4K on-demand content. Any ideas?
longisland94
112
40
Georgia
Are you connecting by wifi or wired? If wired make sure you are not using a separate switch or hub. I had to remove a hub that was limiting the bandwidth.
vipul128
93
28
I am using a wired connection. It is going through a switch because, well it has to in order to be able to have multiple wired devices. In any case, the switch is not limiting bandwidth as I am able to stream on other wired devices without issue and even stream Netflix and Youtube 4K on my TV which is running a wired connection as well.
This seems to be an issue with Dish somewhere as 60Mbit is more than enough bandwidth to stream/download 4K (at most you'd need around 30Mbit).
Isn't there a speed test/connection test on the Hopper menu somewhere? I'm wondering if I run that again if it will help. I don't remember exactly where it is, but I think I remember seeing it when the Hopper was installed. Anyone have any ideas?
