4K Joey Mount
bobvick
4,464
2,163
Northwest Alabama
Is there a bracket for the 4K Joey to mount it behind a flat panel TV? I thought that they made one, but I haven't been able to locate one. Anybody know if they make one, or a way to mount behind the TV (preferably on the back of the set).
Tie-wraps? Or velcro.
Yeah, I could probably use 3M tape or 3M Velcro strips. I just could have sworn they made a cradle or something to mount one in.
There are keyhole slots on the 4k Joey. Just put a screw in a wall mounting hole and hang it on that.
I was thinking of using something like this: Amazon product ASIN B007Y4TUY2 to mount my Joey to the back of a 32" Samsung sitting on my kitchen counter. Have expensive tumbled marble tile on the wall behind it so not screwing holes in the wall. I was thinking if I mounted the mount on the back of the TV I could use long black cable ties to secure the Joey. Anyone else ever try something like this?
I ended up using a mounting screw on the Plasma TV I was trying to get the Joey mounted on, ended up working good. Thanks for the tip. I had never noticed the little mounting holes on the 4K Joey.
An alternative to the velcro might be to use the Command Adhesive stuff used for hanging pictures...the ones that are somewhat similar to velcro. Less likely to leave residue all over the place if you ever decide to remove it. Here's an Amazon link, but easy to find locally at Walmart, Home Depot, etc. I've never used the stuff for a Joey, but I used it frequently for hanging pictures where I don't want nails and it works very well.
Amazon product ASIN B00404YKZI
I use that for a lot of things, especially when I think that it might not be permanent. Usually works pretty good, sometimes you have to be careful with it and paint.
