A Shame Thread
A double stacked lo-pro, with EL/AZ broke off for the middle tie-together, on an under eave mount with studs hit on one side only, no corner braces, and pointed right at trees during a winter install, service out at beginning of spring.
the other one is a LO,LO pro
You mean like these?
Reactions: Tylorert
The "anchored" pole
the country pole
the line of sight boost
Lo,Lopro on a rail
one block non-pen
I could do this all day
Tons of jobs by power lines.
I can'tfind my favorite right now tho, its grounded to a gas main
One time i was in the country no hardware store in sight and had no tapcons, i predrilled the holes in the brick stuffed the holes with the plastic part of the flex clips and then lag screws, dish500 felt solid i know it lasted at least 90 days
Reactions: hank123
you realize you are the type of installer being made fun of right?
that low-low pro is classy. i've got a picture of a rail mount attached to a 2.5" pole, and a low pro on a flat roof mount kicking around here somewhere. they're both AT&T uverse installers.
Reactions: Hutch1814
The amount of garbage I seen in 7 years makes these installs look like perfect Installs.
Sent from my iPhone using SatelliteGuys mobile app
Low pro on a sled? Ive done that, if i didnt have a sled i would just use 5 cinder blocks, a low pro and 4 support arms
Im not an installer
Can we just leave this forum to pics of bad installs with explanation? Whats interesting to see it the funny ones!
