I went to the roof today and i put the pole in its place.
I tried to make it as plumb as i could, but it is VERY hard to do it at exactly 90.0 degrees.
I put the inclinometer at 3 diferent sides, south side, northwest side, and northest side, and gave me 3 different lectures, 89.8, 90.0 and 89.9.... thats the best i got
One problem i had, is when i place the inclinometer ABOVE the mast pole, it read 0.06-0.05 degrees instead of 0.0 degrees. If i try to align this pole to 0.0 degrees, then the vertical pole went to 90.3 - 90.5 degrees and not 90.0.
Which is more important? the vertical degrees? i mean the 90.0 or the horizontal degree 0.0?
Am i gonna have a problem if my horizontal degree is 0.5 or 0.6?
I also followed your advices and put 3 washers under one side of the pole to make it as leveled as possible.
And i also put, the antiseize in the ground bolts... what a mess i did
but i guess the bolts are protected now hehehe.
Hope i will not have a problem with the 0.5 horizontal degree, the vertical degrees i guess they are fine right? 89.9-90.0 is the best i got.
Thank you for all your advices and recomendations.
RamboHack
Monterrey, Mexico
