Hi guys! i made some progress today.
I finally were able to track the whole arc symmetrically, and by the whole arc, i mean from 37.5 all the way up to 135 west.
The last time i was at the roof, i made a huge mistake. when i was at the lowest west satellite (135w), and i push down the dish a little bit and the signal improved, i turned the pole to the west... big mistake! i should have turn the pole EST!... lowering the dish at west rotate to the est. And lowering the dish at the east side, rotate to the west.
Now, i finally tweak a little bit my satellital arc by doing that.
But i one question:
In the "C Band Installation Manual" says :
9.2 : Tracking the Top of the Arc: Azimuth Adjustments Only
1. Point your dish at the most extreme western satellite you can track and gently raise/lower the bottom lip of the dish.
If lowering the lip improves the signals, slightly rotate the mount to the east
Thats fine, i already did that, and i can get the whole arc.... it also says, fine tune the LNB.... i already did that too.
But now in the next step says:
9.3 : Tracking the Bottom of the Arc: Declination Offset Adjustments Only
To fine tune the Declination Offset angle, do the following:
9.3.1. Point your dish at the most extreme eastern/western satellite you can track and gently raise/lower the bottom lip of the dish. If lowering the lip improves the signal, add declination offset
I already did that! i was satellite by satellite 125,131,135 and in each sat i lower the dish a bit, and if the signal improves, i rotate the pole to the east.
Why? the step number 9.3 ask me to do THE SAME thing i already did... and what should i do? lets supose, i lower my dish at 135w and the signal improves... rotate the pole to east again? or add declination offset? which one should i chose? step 9.2 or step 9.3?
I want to fine tune my dish the most i can, but Its confusing.
But i one question:
