LPB on 87W?
Keith Brannen
2,434
1,390
Southwestern Ontario
OK, something must have just happened, as 11804 is now at 87-88 (was 60-61 at 10:50ET this morning) and LPB is now at 63-64 (was at 37-38). Still cloudy here.
Hopefully, it means they have corrected the problem!
Reactions: c-spand
N5XZS
4,546
2,569
Albuquerque, NM, USA
Well here's my signal report from here in New Mexico! :)
SBG TX 1 Freq, 11.749 GHz, H 8.399 MBs
2/1 the signal is hot and sometimes pinning the meter 83 to 85% on GeoSat reciever! They just went off the air.
DC ch. 11.761 GHz, H 2.686 MBs 3/4, 70%.
Ch.2 medical channel 11.802 GHz, H 2.686 MBs 7/8, 71%
LPBS is at 46 to 58%
CNN's feeds 11.960 GHz, H 29.269 MBs 3/4, 72%.
FL ch. 12.046 GHz, V 3.199 MBs 2/3, 74%.
FL, Lottery 12.050 GHz, V 4.799 MBs 2/3, 56 to 65 %.
The weather here in New Mexico is crappy dreary and cold, no rain or snow yet, just high clouds.:hatsoff
FTA4PA
Satellite Guys Family
7,619
5,950
Central Pennsylvania
Whatever the reason, they're certainly stronger now:
11801: 11.1 dB
11804: 13.4 dB
Patient: 11.6 dB
Newsource: 7.6 dB
Florida: 14.0 dB
Sent from my SM-G950W using the SatelliteGuys app!
Same here, LPB is back and all are nice and strong at the moment. :)
Patient Channel: 12.2 dB
Newsource: 9.5 dB
Florida Channel: 12.4 dB
LPB Mux: 11.0 dB
LPB Test: 13.4 dB
N5XZS
4,546
2,569
Here's the 2nd update on this bird,
DC ch. 70%
LPBS 0 to 35 bouncing around like crazy, but locks in nicely with no break ups.
CNN's feeds 75%
Fl ch. 70%
Fl Lottery 28 to 39%
2 stations did not lock in and had to punch in manually listed are...
Ch. 8, 11.805 GHz, H 72 to 73 a LPBS test card.
Medical channel 71%
So basically the signal varies greatly on certain stations. :hatsoff
Keith Brannen
2,434
1,390
Seeing some variations here, some stronger, some weaker, since my 2:07ET post:
11761 - 58-59 (was 60)
11801 - 82 (was 75-76)
11804 - 82 (was 90-91)
11812 - 57-58 (was 68)
11961 - 66 (was 50-51)
12045 - 80-81 (was 92)
12050 - 64 (was 75)
Even with a drop of 10 for LPB, it is still 20 above pixelation/drop off level, so all good if it stays within these parameters even with the fluctuations.
Reactions: FTA4PA
Louis A. Ruiz
Jan 14, 2019
6
9
NYC
Just to let you all know I have been noticing past month overall cxr level from Louisiana Teleport was very low peaking around 40-45 C/N level. (1 meter channel master HDVR 3500 GeoSat) as of yesterday Mon 12-15 it is now back up to full power (85-87%) The test carrier @ 11804H S/R 1.250 which is usually higher (normally around 95-97% was only at 75-80) It looks like maybe maintenance work done on antenna or HPA. Anyone with dish less than 1 meter may have a problem receive LPB due to low carrier level. I never had an issue receiving mux with 1meter antenna and proper peak.
As far as other H down feeds Sinclair 11747 S/R 8.4 does fluctuate sometimes. Bear in mind the CNN transponders either H or V polarities will have marginal levels due to 5 mhz carrier levels. Sometimes lower sometimes higher. If someone can correct me on this I believe SES2 spacecraft transponder power is 90 watts good for 36" antenna receive. Also it also depends if transponder itself has padding or attenuation provided per customer request.
Louis A. Ruiz
Jan 14, 2019
6
9
NYC
11761 - 58-59 (was 60) 84
11801 - 82 (was 75-76) 87
11804 - 82 (was 90-91) 1 meter Long Island NY 97 as of 12-15
11812 - 57-58 (was 68) 86
11961 - 66 (was 50-51) 84
12050 - 64 (was 75)
Reactions: Keith Brannen
LocutusOfBorg
Free speech is more important than your feelings
13,556
7,721
USA
I seem to be on the ragged edge of receiving LPB. I'm getting between 8.1 and 8.3 dB using USALS positioning. tvrosat says I need 8.5 dB. I'm using a 1.2 meter dish that is peaked as much as I can get. The footprint map shows that I'm in the 50-51 dBW signal strength range. So, I changed from USALS to diseqc 1.2 and got the signal level up to 9 dB. That should stabilize the signal until the next snow or rainstorm hits. I was expecting to get better performance out of this dish though.
comfortably_numb
17,840
26,144
Kansas City / Las Vegas
Have you tried it with the dish fixed on 87, no motor? That signal is finicky.
