General tech question: How does unpowered Dish transmit signal over long coax?
BarnRat
610
1,250
SW USA
Just curious how this works . . . The roof Dish antenna is not powered. How is it able to transmit a signal thru coax that is 100+ feet long? Is it powered thru the coax cable from the receiver? My internet ISP uses the coax to pass DC current to the roof dish and also pass signal back and forth. Does Dish antenna do the same thing?
Think of it like a TV antenna, it receives a signal from the air. The receiver, a Hopper 3 in your case, will supply the power required for the built-in switch at the LNB attached to the dish. All that does is select the proper satellite signal for the channel you have selected.
It also powers the LNB. Even satellite dishes without built in switches require power.
Max length of coax between Hopper3 and Joey3?
54.1 Versus 54.3 Remote Controls
