First of all this is a pole mount on the ground with the tremendous benefit of allowing you to stand flat-footed on the ground to tune and tweak the dish. Works great!
This AT9 replaces a Phase III Triple LNB Elliptical dish that was mounted about 15’ up on a 25’ Rohn tower that has a Winegard HD antenna for local OTA digital and analog reception. DirecTV receivers are HR10-250 and R10 both with dual tuners and TiVo service. I do not have the MPEG 4 capable HR20 receiver yet (without TiVo) but just
installing the AT9 for future use when most channels on the DirecTV sats are MPEG 4
only and my current receivers become obsolete. I receive HD locals OTA so no real need
at this point for an HR20.
The hole is 9” diameter and 26” deep with the first 2” being gravel for drainage. This leaves 2’ of pole in the ground and 6’ above. It is a standard 8’ steel fence post 2 3/8” OD HDG (Hot Dip Galvanized) 13 gauge (.095 wall) by Allied Tube & Conduit. There is a 1/4” all-thread rod inserted horizontally about 8” up from the bottom to prevent any possible twisting within the concrete over the years.
The board is a pressure-treated ACQ 2 x 10 (actually measures 1 1/2 x 9 1/2) cut to 31” length. All lag bolts are stainless steel to help prevent corrosion from the chemicals in the pressure-treated board. The fence post brackets (2 above and 1 below the J-mount base plate) are Simpson “Strong Tie” brand and are very heavy duty. They each have one roll pin (tension pin) inserted to prevent any possible twisting on the pole over the years.
There is one short brace attached solely to help support the weight and leverage of the
rather heavy AT9 dish. The J-mount has 4 bolts (2 on each side) to align and secure the mast but the lower 2 bolts only serve as a pivot point and most of the weight and leverage of the dish is held by the upper 2 bolts. Not very good so that is why the short brace is used for added support. Note you can not clamp down the brace until after the mast is aligned to absolute plumb. Additional support to prevent “wind shake” of the dish is provide by 2 horizontal long braces anchored back to the Rohn tower.
Tuning and tweaking was accomplished with an AcuTrac22 Pro meter ($114.95 in my case) and was well worth the extra money. Took about an hour of tweaking. I am located in Plano, Texas (suburb of Dallas).
This is probably way more than 99% of you want to know… enjoy the photos and I'll be most happy to answer any questions.
Craig
Craig
