T tonystewart20 SatelliteGuys Family Original poster Sep 21, 2008 42 0 Jun 3, 2009 #1 Did an install put in an EA. Customer then decided they wanted foreign language programming only available on the 118.7. Any one know of a reason i cant set up a 500+ and run one line off of it to the lnb in on the 1000.4.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 2,155 8,814 Mankato, MN Jun 3, 2009 #2 nope...works just fine that way 118.7 line to the EA dish
C chainblu SatelliteGuys Pro Aug 25, 2006 634 100 Jun 3, 2009 #3 Agreed. Should work just fine. Especially if you set the skew to 90 degrees and peak just the 118 sat. for best signal.
K k4106 Active SatelliteGuys Member Jul 8, 2004 19 0 Jun 4, 2009 #4 Can the same be done with the 1000.2? I intend to use a 26 inch dish for 118.
F Filmz Member Jan 20, 2009 8 0 chicago burbs Jun 5, 2009 #5 yes it can be done ..... basically anything thats dpp can have that setup it would be just like having a 61.5 wing dish or 129 wing dish
