522 Program guide appearance
dizzydean
16
Anyone seeing problems with the appearance of the program guide border on the right-hand side of the screen? The last two units I have installed have had a "warp" in the border of the guide on the right-hand side only. After selecting a channel the picture is fine. This has only started happening in the last few days. I have not seen it before. And no, it is not more pronounced after happy hour, and yes, I can pass a drug test.
I've seen this blooming on a lot of older TV's using the modulator. Turning the brightness down could help. Keep in mind that the TV2 modulator is higher power and you need to use the attenuator on short cable runs. For TV1 you should be using the higher quality outputs, SVideo if possible but at least the RCA's.
AAAAAAAARGH! Just gotta vent (new install)...
DVR 522 TV1 stuck on "press select to contineu"
