A few channels show "Searching for satellite signal" message. Only noticed recently.
KillrBuckeye
91
Suburban Detroit
As the title states, there are a few channels in the 250-260 range that are either pixellated/stuttering or show the "Searching for satellite signal" message. My wife noticed this the other day when trying to watch Lifetime. These channels were working fine a couple of months ago (I can't be sure exactly when this started). Anyhow, our dish was professionally installed and aimed, so I have no clue what I need to do to fix this.
I took a picture of the signal strength screen if it helps. I'm not exactly sure what I'm looking at:
Any help you could provide would be greatly appreciated!
shmeff
444
Is tuner 2 the same signal? Is this a hi-def dvd? Do you have a multi-switch?
roshambo360
Dec 9, 2006
8
I started having the exact same problem a couple days ago. Most HD channels are so bad it's unwatchable. It's not just you!
roshambo360
Dec 9, 2006
8
I know this sounds completely crazy, but unhooking both satellite connections from the back of the DVR, plugging them back in, and rebooting the receiver fixed the issue. Strange, but true!
mark40511
SatelliteGuys Guru
Jan 2, 2006
141
Lexington KY
I will add to this..........I have 2 HR21's and a powered SWM.........The swm is on the HR21 in the bedroom.......I have had pixellation probs in the past but I rebooted the SWM and both receivers and this has solved my problem. I never see pixellation on SD HD or HD locals anymore. My problem is with A&E HD..........when I tune to this channel, it says searching for sat signal 2 771 for approx 2 min's then the channel comes in and plays fine with no pixellation. This just started recently and again it's only this one channel. This happens on the HR21 in the living room and not the one in the bedroom. Once the channel comes in it plays flawlessly. I rebooted the receiver which didn't help. Everything else works great. It snowed three inches the other day and I never saw the first pixel. My signals on all sats are 80 or above. Tuner two is a tad lower than tuner one but still well above 70.
KillrBuckeye
91
Suburban Detroit
Okay, the problem went from bad to worse! Today there is no signal reaching the HD DVR receiver! I checked signal strengths and every even transponder reads "0". I ran a system self-test and it showed 0% for both tuners. Two other standard def receivers in the house are working fine, and the DirecTV representative told me the problem is probably somewhere along the cabling that runs to our HD DVR (just as several people in this thread presumed). They aren't able to send someone out until Dec 31!
I've tried unhooking and reconnecting the cables to the DVR and jostling the cables where they come into the house, but it hasn't helped. Just in time for the holidays! This really sucks...
Zynergi
938
NC
I would check all connectors and make sure the cable is set properly and make sure the stingers are straight and not bent.. Also look for any tight bends in the cable run from the box to the dish..Also make sure all connections are tightened down with a 7/16 wrench.
russ222
98
wisconsin
make sure you dont have any snow on the dish or lnb.s..my local hds had that problem yesturday and i wet out and slightly tapped the dish and presto they all work great..so check your dish>>>>
diggerTV
Aug 9, 2007
15
Central Illinois
I'm having a similar problem, but it is with all my HD receivers and I get the 771 message for only the sat HD channels (my HD locals are ok). Any suggestions?
KillrBuckeye
91
Suburban Detroit
Last night the signal suddenly got better and I am receiving most channels (except for the channels that were originally a problem when I started this thread). I don't think it was snow/ice on the dish, because I checked signal strength on one of our standard def receivers and it was 99. I have no clue what's going on, so I guess I'll just wait for the tech to come out and figure it out.
drx6
37
central PA
same problem here and my install is only a week old.
It mostly happens after dark and is fine during the day
drx6
37
central PA
Also - I had read on a directv.com forum that if you're connected through the s-video jack that it can sometimes cause this error to happen. I disconnected my s-video and it worked fine the rest of the evening. but I've seen the issue crop up again as recently as last evening around 11pm
