Two days ago I had a Dish Tech. come out to replace two 722Ks with two new Hoppers and one new Joey using a Duo-node. All cable was 3 ghz.
First Hopper worked great.
Second Hopper didn't authorize at all, as happened to two additional new Hoppers at that location.
So he replaced the Duo-node (logical).
Then the second Hopper worked, but the first didn't. The Joey also worked.
The Tech. went home leaving me with 1H/1J running and 1H down. I was OK with that since he had spent six hours getting that far.
Another Tech. came out the next day two replace the non-working Hopper (again), but first I suggested that he reverse the Hopper outputs on the Duo-node to see if perhaps the Duo-node or cabling was bad. The Hopper problem reversed working vs non working. That meant Duo-node probably bad but cables good.
So he replaced the Duo-node after testing the three cable signals incoming from the dish... all OK. After replaceing the Duo-node... same problem!
Then (his Idea) he swapped the incoming cables from the dish 1, 2, 3 became 1, 3, 2 and lo and behold the whole system worked just fine, BUT nobody knows why! STRANGE!
Only one problem remaining is how to get more than two UHF remotes working on a Hopper... any ideas?
