Bell/shaw direct help
oldben
Oct 18, 2012
7
Newfoundland
Hi,
Seems like it's not possible to get BellExpress VU in Florida,tried just about everything and no signal...there was no problem past 4years until a few weeks ago...ony here 3 mo. a year but i miss my Canadian programs...Will a biggger dish make any difference?
What about star choice (Shaw)
My 1st post so don't know if i'm in the right form...
Ben
Mr Tony
2,068
8,362
Mankato, MN
welcome :wave
I moved your post to the Canadian forum
no. Bell launched a new satellite this summer which severely cut off the coverage here in the states. You need to be about 150-200 miles from Canada to get a signal.
Shaw works fine all the way into Mexico
rocket69
910
On Your Roof!
yes and no.. You would need a world direct dish and could only point it to one of the two sats shaw uses. If you cant bring one then two 36" (0.75M) or larger with one dual standard lnb each and a 4x4 switch will get your goods. Larger is better but with most storms i see in FL your SOL if its 36" or 6'
Vote NDP!
rocket69
910
On Your Roof!
that dish will work just fine and if your going to run your boxes back and forth from NF to FL you will save some phone calls having them switch the activation or setting up a snowbird.
With that new dish all your HD that you get in NF you will have some in FL as alot of the new hd programs are on a new bird that maps out part of the us
