Have changed dish to G19. Finds all other transponders but cannot find Freq 11842. Have it programed in correctly. No signal quality though. Have a Viewsat Ultra light. Also is LLBN off of AMC 4 already?
Tried every small adjustment elev and skew, can't get a lock. Back to amc4 for now getting great numbers there.
Yes will lock on several others with no problem.
Are you finding that TP much weaker than the other on the bird? I've done a few repoints here in eastern ME and generally find 3ABN 0n 11842 to be quite weak. One customer is getting a 1.2m dish just to keep lock. Average Q seems to run 35-40 while other TPs are 70-90.
Thanks, Eric
It is not so much that it is weaker, for some reason when you bump the dish to the east a little 11842's signal increases.
Yes, that does help a little, however 11842 seems to be a weaker transponder than a lot of the others. I finally got up to 50 where lots of the others are up to above 70, I'm quite dissappointed with the move so far. Also now the sound on the 3abn channels is quite a bit lower than others. Hope this changes soon.
