Directv SWM Please Help!
cinsu
305
44
The States
I wouldn't think it would vary that much if you were to move horizontally across the U.S. but maybe vertically would. I am used to seeing about the same -25 as you or MAYBE -21 on a really hot LNB. I have been curious what they get in Hawaii or Alaska.
cinsu
305
44
The States
37 elevation (up and down, bolt on the left), 194 azimuth (side to side, bolt on right), 81 tilt for the 101.
The 119 would be at 31. Try raising the elevation a few degrees and swing it to the left.
texasbrit
Cutting Edge
Apr 12, 2006
3,654
365
Good to hear that. We quite often see posts from people who are aligned on the wrong satellite...
Satftafan
100
8
Longview texas
OR, WA, ID, NV, CA. I was in VA last month and couldn't figure out why all the ODUs looked strange until I realized the tilt was almost completely opposite of what I usually do.
That said, OP, it would be ideal to get your zip code because the differences between the 101 and 119 can vary significantly depending on where you are. With that we can give you an accurate elevation, azimuth and tilt. Definitely sounds to me like you are on the 119.
I hope you weren't working in Manassas dma because that's a bad dma
drwindmill
55
Worked great for a few days now getting the 771 every couple minutes. 110 is low, I think the others are ok.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,796
17,739
Cheshire CT
Don't worry about 110, the signals are pointed towards Puerto Rico so they should be low. The rest of your numbers look good, but what about 99c and 103ca/cb?
drwindmill
55
I am in the 90's everywhere but on 110. Maybe it is my receiver. Every few minutes I get the 771 error and it pauses for few seconds and comes back.
