DPP44 switch
maddawg
283
Just installed my DPP44 and connected my 121 dish (separate dish) to port 4, but after performing a switch check its showing NC. Verified the signal by connecting my receiver directly to dish with a signal strength of 74. Power inserter is connected to port 1 (dish 501). Any help would be appreciated.
port 1 = 119
port 2 = 110
port 3 = 129
port 4 = 121 (n.c)
Switch your satellite input cables around on the DPP44 to check if port 4 is bad on the switch. Unless you have a legacy receiver it doesn't matter what port 121 goes on.
Jordan420 said:
If using a seperate dish for 121 are you using the correct lnb?
121 & 105 sats use a different lnb than the rest of the birds.
Can you tell me what lnb that must be used?
Dish Pro or Dish Pro Plus FSS LNB's. They have a fancy DP logo on them. Ones that just say Dish Network on the front will not work.
The following is a Superdish with a good picture of the DP logo on the 121 FSS LNB.
http://rweb.echostar.com/departmental_content/TechPortal/images/tech/techequisuperti121.jpg
Or try the Echostar tech portal for everything Dish-Pro...
Click HERE
Switching the ports *may not* help. The DP44 states right on it that PORT 4 is for FSS.
Does anyone know if 501's support 4 slots? I am not familiar with that box.
So I am required to have a dishpro FSS lnb. Currently I have a invacom LNB on the dish.
Iceberg, question, can I not use a multiswitch with the invacom to acheive this? One port for H and othe for V?
nope. Stacked frequencies take the H polarities and makes it V and "stacks" it on top of the original vertical polarities.
Stacked single LNB's you can use a high frequency splitter and go to 2 recievers. This is how StarChoice use to do it.
If it isn't stacked, then the LNB is unstacked. Most LNB's are unstacked.
Linear Dual Standard LNB for Pansat receiver FSS LNBF
I found this on ebay,,,would this work?
nope
It SPECIFICALLY have to say "stacked". If it doesnt say stacked, it wont work with DishPro (it will work with Legacy)
Iceberg said:
nope
Ok, could you point me to where I could get one of these? I'd like to use a dish 300 with it. Would that be possible?
nope
Need at least a 30" dish to get KU band. KU band is a lower powered satellite so that is why you need a larger dish
Couple options
-look on Ebay for a SD LNB set. People are selling them separately. That will work
-Look for a StarChoice LNB. It has to be a single output and say stacked for it to work.
Software version L2.66 for ViP 211/411
Received new annual bill!
