Help!! 522 UHF Remote TV 1 Question
jimboeau
463
Western WI
I just setup a 522 to have a UHF Remote on TV1 as well as TV2. They both have different address and they both work, however I can't get the UHF remote for TV1 to work from a different room. Does the UHF remote for TV1 work through walls in a different room? Does the UHF remote for TV1 work using the same little antenna that the TV2 UHF remote uses? I need to use TV1 in a different room from the receiver. Thanks much for your help....
does it say UHF on a button of the remote? for TV #1 and have you checked that no one swapped remotes on you? and yes it uses one little UHF antenna for both remotes
Thanks I, exchanged the UHF IR/PRO 6.3 with a UHF pro 8.0 and now it works fine. Thanks much....
Sarched but couldnt find so do you know
522 Setup problems...
