Ok I have to first off say that with my ku motorized system the Microhd has been the best receiver I have ever had. Hands down! I seem to catch alot more than I have with any prior receiver. However since installing my 9 ft Bud and getting it connected to the micro I have noticed some issues with signal locking.\
I know I am in the arc, I have tweaked this thing alot and what I do is bring the birdog meter to the dish, remove the h-h motor and use the handcrank so I can track the arc with the meter and see how sats are lining up. my declination is withing .15 at least, and I have tweaked it to the point where I am almost perfectly locked in.
Now here is the issue with the micro, on the 87 Luken mux It will show 10pct quality to 0 like the micro does on a few tps if you are not locked in, well then the micro will start out of nowhere showing a bouncing signal between 20-60 bouncing all over and then when I go to a channel on the mux it will come right in and then say 71-73 steady quality, but as soon as I go to another tp on the sat then go back to the luken mux I have to do the same thing over again by going to the sat on the sat/motor list then change back to the channels on the luken for the steady signal, I am also having the same issue on the anik 107.3 ctv hd tp for the 20 or so ctv hd channels. On all the other sats I am getting even s2 9/10 tps at a mid 70's quality which is great on the micro btw, but these two sats 87 and 107.3 I am getting this weird signal lock. If this is the case maybe the micro is not necessarly a great receiver for c band.
Have any of you ever experianced locking issues with the micro? I have read where people have had other microhd problems, but not so much a locking issue. The whole time I thought I was off and couldnt get the 87 mux But now I realize I am getting them it is just the micro is taking a bit to lock which is weird considering when it locks it is at a very high quality, I could understand if I were off and it took a bit to lock, but 73 quality is high.
