Problems in dual tuner setup??
thielepr
Jan 6, 2009
6
PR
I just upgrade to an 722 DVR HD dual tuner. I use a DP44. The thing is I not able to see the two television at the same time. If I'm see the TV1 the TV2 loose signal and it keep looking for signal. If a reset the receiver then I can see the TV2 but the TV1 go to look for signal.
Ftoutloff
SatelliteGuys Guru
Apr 10, 2007
121
Green Bay, WI
try flipping the separator - if the problem follows to the other tuner your problem lies elsewhere. If the problem stays the same you have a bad tuner
thielepr
Jan 6, 2009
6
PR
My problem it that I can't see two TV at the same time. If TV1 is ok TV2 is looking for signal. If TV2 is ok TV1 is looking for signal
