kstile said:I set up my Favorites so that I have only 6414-6416 and 8610-8616(?). And, of course, per this entire damn thread, 13-01 (OTA, in yellow).
The reason I did this is that I can see when Fall rolls around that there are some shows I'm going to have to record in SD b/c I'm out of space on the DVR, but others that I will want to be absolutely sure I record in HD. If I used 04-00, 05-00, etc. and it always recorded HD (b/c of the setting for HD prioirity in locals), my DVR would fill up way too fast. That way, too, I can be sure to record SD programs in SD (Survivor, for example) and not use up valuable hard drive space...
long_time_DNC said:I'm hoping they'll enable the USB port(s) for external storage relatively soon. I'd get a 500gb drive, hook it up and dump a bunch of HD stuff onto it.
Next up: re-peaking my 1000 to 129 and seeing what that does for the 20-minute cyclic drop-outs.
I'll have to be careful and see what balance I can strike between getting some gain on 129 without losing 110/119.cebbigh said:Agree. I've been copying things to DVD. But it just doesn't look that great for sporting events.
on re-peaking: Good luck. With the 1000 it's a balancing act. You can peak on 129 and completely loose 110/129.
long_time_DNC said:I'll have to be careful and see what balance I can strike between getting some gain on 129 without losing 110/119.
I've dumped some stuff to DVD, but as you said, it loses something in the translation.
The 1000.2 isn't out yet...not until the Fall.
