shaw direct two dish lnb? switch ?
bjkrieg
Dec 5, 2013
3
mexico
new member in mexico p.v. have two 7ft dish, that are set to dish net work, now i would like to set up to shaw direct, realign dishes, one to each sat.
1 Can i use the duel outlet lnbs.?
2 i have a muli-dish switch model dp34 , 107107 trying to hook 3 older non hd recivers well this work.?
3 i was told the dishes well work is that right.?
4 and i need remotes.
5 thanks for all the help, yes i am just getting started, pick the recivers up tomorrow.
Sure you can use 2 dishes for Shaw for Anik F1 and Anik F2, don´t count on getting Anik G1 here in any part of Mexico.
I know even an elliptical dish works as far south as Central America.
So with one dish for each sat (F1 and F2) you´ll be better off in case of rains.
You´ll just need standard lnbs (don´t use the extended which is for G1).
Sure you can use dual output lnbs.
The switch you mention is for Dish, and to the best of my knowledge I don´t think it will work with Shaw,
Shaw uses a 22khz switch tone,
