The Titanium Future Product Line Dream Thread
Jim S.
When someone asks you if you're a god, you say yes
5,677
1,313
FN11od
I'd like a source for these:
that doesn't charge as much for shipping as the item costs. (The only source I can find is in Canada.)
I'd like a Peltier-cooled LNBF, although I don't know if most receivers could supply enough current to run one.
I'd like a receiver with 4:2:2 decoding and a network media player that handles all formats. Basically, an AZbox that isn't full of bugs.
Cham
VE4GLS
2,550
1,122
Boonies
Guess we should add 4K/H365 to the want list? :)
Though I won't be upgrading TVs until my current one dies...
Hockeynut
850
744
Sat Farm in NC.
I want a receiver that doesn't move your dish until you actually select a different channel.
All receivers in my sig do not move a dish until the ch is selected.What receiver are you using that does this Magic Static?..The 9200 will move a dish just scrolling through satellite`s(is a pain) but not when scrolling through ch`s.
Magic Static
7,498
4,853
Montana
Yea, just like the 9200 it moves when you select a different list. The microHD is the one I was referring to. I don't want it to move and switch to the last channel I watched in any list I pull up, Satellite or Favorite. I want it to move only if a select a new channel.
toucan-man
2,693
25
Wisconsin
That's the klutz factor, coupled with a less than stellar remote, which makes me want to pull someone's hair out. In China, no doubt...
primestar31
13,614
14,176
Beta Omicron Delta III
Your wish is my command for the flat coax! http://hypermegasat.com/Accessories.htm#flat coax (FREE shipping.) Nearly everything he sells is FREE shipping. He doesn't jack his prices sky-high to compensate either. He's also a Titanium reseller...
Martyn
636
278
Annandale, VA
I'm surprised no one has suggested a receiver that monitors the on-screen sports graphic and dispenses and ice-cold beer from its internal beer server everytime your team scores.
pwrsurge
919
30
Canada
4:2:2 coming soon??? Christmas Gift??
4:2:2 is already here :D
Even if performance is not the same as separate dedicated LNBF's for C and Ku band, I would not mind seeing a C & Ku band combo LNBF with dual outputs for C-band and dual outputs for Ku-band. Right now, only single output models are available in the market so the only inexpensive way to run C & Ku band off the same dish for 2 or more receivers is to install a dual output C-band LNBF in the middle and a dual output Ku LNBF offset by 4 degrees on the side. This is cumbersome as all Ku-band satellite positions need to be programmed separately and some performance is lost by having an offset LNBF on a prime focus dish.
The main issue with those C & Ku band combo LNBF's is the spacing between the C and Ku LNBF components is fixed so based on the F/D ratio of your dish, it can be almost impossible to adjust the focal depth of the LNBF in a way that both C and Ku band reception is maximized. Because of this, the combo LNBF design should have a way to adjust the distance between the C and Ku band LNBF components.
I know an orthomode feed is the ultimate performance solution but the cost of this makes it out of reach for most people.
WIN FTA Equipment TONIGHT!
Signal booster
