New Dish Network Receivers Coming in 2009? How wil Dish Network Handle NTSC turnoff?
Mike500
1,338
Thiepval
It has got to happen. Manufacturers will not include NTSC tuners after 2009? Dish has got to make receivers with ATSC modulators for TV2.
If memory serves TV2 output can also be sent as a cable signal (maybe QAM)? This would solve the problem too.
That said; it would be interesting to see if they include an ATSC modulator as this would make it much easier to send HDTV to TV2 and have a dual HD box.
Cheers,
The analog shutoff does NOT affect Dish. It applies to over-the-air analog signals only. Sure, Dish might include NTSC tuners in their receivers, but that's just a benefit. They're not necessary to receive Dish's service/programming.
No deal
On the tech chat last week this question was asked and answered. They said they couldn't do this due to the fact that the providers wouldn't allow the mto provide a pure digital signal output that could be copied easily.
What I'm saying is that TV sets made after the shutoff will not have NTSC tuners nor Analog cable capabilty. As I recall, TV2 is either NTSC analog or cable analog.
Mike
TV's will be made with NTSC tuners for years after 2009, the only thing that will happen in 2009 is that OTA broadcasts will no longer be NTSC.
Mike
Don't count on it. How do you know that the industry will continue to provide hardware to support nonexistant transmissions? No tuner has supported UHF OTA NTSC channel 72 for years.
Perhaps (though I think my TV still scans to 81), but that channel was NEVER used.
If NTSC & ATSC have been integrated into the same chip, there really isn't much reason for the manufacturers to remove it. Also, if a set is "Cable Ready" would it have to include the analog channels (since they are still used by cable)?
Eventually Dish may have to do something. Maybe they will blow off modulated output completely, and provide a cheap STB to act as a remote box.
That doesn't make any sense. If by some chance your remote TV doesn't have an NTSC tuner I don't see how an attenuator is going to help.
Speaking of which, I've seen posts from people with "monitors", i.e. TVs with NO tuners, set up for TV2 usage with a dual-tuner box. They can't use the coaxial (RF) feed to run TV2. You can't "tune" to the channel you pick on the receiver for the 2nd TV. Does the attenuator resolve that ?? I didn't think it did.
They could use RCA, of course, but getting them in the right lengths could be difficult for the average person.
He is aware of that His comment concerned the fact that DISH receivers output NTSC and that televisions with NTSC tuners might become scarce. Personally I think that we will see NTSC tuners for some time to come. But I could be wrong. I also suspect that amny cable systems will use analog for awhile (although ona limited basis) so sets may still have analog cable tuners as well.
n0qcu is correct. We did some research on this a ways back. TVs equipped with NTSC tuners will be made for many years to come, to facilitate old devices such as VCRs, certain cameras, old video games, etc. There is little to be gained by reducing their reception to channels 3 and 4, and no cost savings to eliminate NTSC entirely. As stated, the chips have both NTSC and ATSC built in.
We can forget the hope that Dish (or anyone) will pump out a non-DRM'd digital signal over coax, making it easy to copy.
What am I missing here? How does an attenuator help out in this scenario?
I would think that perhaps dish can pump out 8VSB/ATSC but downrezzed to 480i on the RF ports.
On the tech chat last week this question was asked and answered. They said they couldn't do this due to the fact that the providers wouldn't allow them to provide a pure digital signal output that could be copied easily.
But couldn't a low power ATSC/HDCP modulator eliminate the copying?
I'm assuming that ATSC VHS Recorders and DVR with DVD Burners and/or Hard Disk Drives are licensed to use HDCP which either allows a program to be recorded, recorded once, or not at all.
But then Vern, I'm confused.
Encryption isn't part of the 8VSB spec for ATSC spec. What you're thinking of are the so called "broadcast flags" which I believe the FCC has stricken down.
HDCP is for DVI and HDMI not for ATSC.
Cheers,
? to those that rent houses
HELP!!!!! For the life of me I can't find satellite 110
