Does anyone have their VIP722 HD DVR receiver hooked up to more than 2 TV's in the house? If so, do you simply split the home connection output on the back of the receiver? I understand that TV 2 and TV 3 will receive the same programming.
On the 722 you can set the modulation to output Tuner 1 to the Home Distribution as well.
I would like the VIP722 installed downstairs within the home theater using the HDMI port (TV1). I would then like to split the "home connection" port into two and run coax to the living room and bedroom. Is this possible? Could both tuners be controlled via the "home connection" port? An IR repeater would be installed to control TV1 in the living room and the RF remote would then be used in the bedroom to control TV2.
I possibly could split the "home connection" port into 3 and control the TV1 tuner within the home theater (HDMI) and living room (coax) and the TV2 tuner within the bedroom (coax) and daughter's bedroom (coax).
all you do is take the coax from home distrubution and feed the TV 2 and TV 3. and you will be UHF remote to operate the 2nd and 3rd tv.... you should have 1 uhf remote, just get your self extra uhf remote and program it to the same remote address.
to program remote address.
with tv 1 remote press menu twice. that will take you to the sys info screen.
now take uhf remote and press and hold SAT button till it blinks.
now press 3#Rec buttom all at once repeat this 2 to 3 times, and the small tv icon should blink.. repeat this same process to program the other uhf remote for tv3............
hopefully you understand...
...Then we looked at the modulators for the 722 and the 625. For the 722, we set the tuner 1 for cable channel 73 and tuner 2 for cable channel 75. On the 625, there was no way to set the tuner 1 output for anything other than channel 3 or 4, so we went with channel 4 (we have a local channel 3) and tuner 2 we set for cable channel 85. ...
...PS-On the 722 you can set the modulation to output Tuner 1 to the Home Distribution as well.
I have two 622s, I don't remember seeing a coax out for TV1, am I missing something?
I don't have my VIP722 yet, but I assume the "home connection" RF port can be setup to distribute both TV1 and TV2 on two separate channels. For example TV1 (tuner 1) on channel 29 and TV2 (tuner 2) on channel 42.
As Popcorn says in the post between ours, the Home Distribution Port will do both. You will need to set the Modulation in the setup menu for TV1 as it is set to off to begin with, but once you select a channel, the same cable that runs to TV2 (if it is hooked up with coax) will work for TV1 on the other channel (just make sure they are not the same as an OTA channel in your area and are at least 2 channels away from each other (TV1 and TV2). For example Channel 4 & 6 will work, but 4 & 5 would not.
Geoff
