Porgram Guide "No Info Available"
redsalmon
202
Soldotna AK
My program guide starting in one hour (1 PM AK standard Time, 5 PM EST) says no info available and won't advance beyond that. Anyone else seeing that? Anything happening that we should know about, or is it just my system? 622 DVR.
I've had that happen to me a few times w/ the 622. Usually running a 'check switch' will force a guide download.... give that a shot
Rob
Running the check switch worked after it reloaded the programing guide. Thanks. It's the first time it has happened to me with the 622. I'll remember it the next time.
It happened to me on my 622 the other day. 1st time for me on my dvr. It must have started about 10 minutes before the end of an active recording, so the dvr continued to record a 1 hour show beyond it's end. Must have not received the queue that the shopw was over. I got home from work, and found it at 3:45! I checked the guide, and sa the "no info's" I checked the recording schedule, and it said the same for everything. I canceled it quick, before it filled up the harddrive, and started deleting things. I ran the checkswitch, and it fixed it right up.
So that could have been scary, and wiped out recordings I hadn't seen yet!
$20 for HD is nuts
teja tv gemini tv
