A friend just "moved" from Jefferson City, MO (65101) to St. Louis (63108) to get the local HDs out of the STL area.  He has a Dish 1000 pointed at 110, 119, and 129.  He checked to see if his dish could get the satellite that is sending the signal (118) by changing the satellite at the Point Dish menu.  On Transponder 2, he's getting a 75-77 signal strength, but it says wrong satellite.  We figured that this meant that he was able to get the signal from the 118 satellite, but that we needed to "move" his service over to the new address in order to get the satellite to lock.
He called and got everything switched, but so far the locals haven't showed up. He's gone in and done a "check switch" but the 118 doesn't show up. Does he need another satellite or 4th LNB in order to get the satellite to lock?
