Please Help with self install for 61.5
tarheel
29
Southeastern NC
I have a Dish Pro dual lnb feeding 1 E rec. #322. I bought from a flea market a VIP 211 & a Dish 500 with a DP quad lnb. I want to get sat. 61.5 & feed both the 322 & VIP 211. Can you tell me how I can do this? Thanks
You need a DP34 switch to combine 119/110 and 61.5 to feed the 3 tuners. Or you can get a Dish Pro Plus Twin LNB and you can feed the two receivers from the DPP Twin.
If you go with the DP34 switch, you'll need 3 cable runs (one from each orbital location) to go to the switch. Then you run a cable to the 211 and 2 cables to the 322.
If you go with the DPP Twin, you run a cable from the DP Dual (61.5) to the SAT IN input in the DPP Twin. From the DPP Twin you feed each receiver. You will need a DP Separator for the 322 (dual tuner) receiver.
