Dish 1000 or 1000.2
Skyhi
3,518
24
NE Ohio
Is there anyway to tell what Dish I have? I'm hoping its a 1000.2. TYIA
The 1000 dish gets 118.7, 110, 119, and 129.
The 1000.2 gets 110, 119, 129 and has an open input that can be used to pull in 61.5 as a wing dish. It can also feed 3 Dual Tuners (such as the 625 or 722) with only 1 coax going to the receiver and a Dish Separator.
Geoff
Nope.
A D1000 gets 119, 110 and 129
D1000.2 gets 119, 110 and 129
D1000+ gets 118.7 119, 110, and 129.
The difference is in the LNBs and the size of the dish. The 1000 has a Dpp Twin and a Dp Dual. You can feed up to two dual tuners with a single cable run with a D1000.
The D1000.2 has a triple LNB that can feed up to 3 dual tuners with a single cable run.
Nope.
Was I correct that the 1000.2 can accept the feed from a wing dish for 61.5???
I almost put that I was not certain about the 1000 stuff, but didn't. Guess I should have.
Geoff
The 1000 was a short term answer to receive 129. Your best bet is to use the 1000 as a 61.5 dish. Set the skew at 90 and put the DP dual {or single} in the middle, link the DP to a newly purchased 1000.2 with the supplied triple. 4th port. You will see a stronger signal level on 110-119-129 using the 1000.2 AND be able to light up 6 tuners......Have fun
722 DVR and TV2 dilemma
DPP64 Switch
