I have been trying to get this Dish 1000.2 pointed for what seems like forever. I have finally gotten 110 and 119 in with a fairly strong signal (using a 311 receiver). I am confident the mast is plumb but when I do a check switch it only shows 119, 110, Conn. When I go to the signal strength screen and put it on 129, transponder 16 I get a signal of 78 -- but it says it is "Not Locked Echostar 119 West". What gives?
Sat 119 is also 78 strength (on transponder 11 or 16). I thought my problem might be trees, but if so why is it showing such good strength on 129 -- but as 119? I also show good signal strength for sat 121, I noticed, as I was on my way from 119 to 129 on the screen.
If anyone can offer some advice / suggestions it would be very much appreciated. Am missing my local channels until I can lock in on 129. Zip is 43973, skew 126 (set by the guy that sold me the dish, and he says that is what he sets for for his customers w/ my zip), elev about 31. Not sure the azimuth but I have it peaked by the signal meter from the receiver.
Also, I have seen posts where its said to tweak on weakest sat -- in this case 129 -- but how can you do that if you don't have a meter that tells you which sat you're looking at, and the check switch doesn't recognize that sat?! I am also a bit confused by the ports on the switch/LNB for this model: can you hook a meter (cheap signal meter is what I have) to a different port other than 1? Sorry, but this is soooo frustrating....
