Uplink Activity 6/26/08 6:05 PM EDT - 2 mapdown changes
The uplink tool is running in full automation mode. Hope I compiled the code correctly this morning before I put it in production :)
I take samples. He checks regularly for changes. :) Even if the NIT/SDT versions change, there may be no relevant changes to report.
That's true and same time only new version of NIT/SDT will carry changes, so the moment of changing the version should trigger a process of comparison and producing a report in case if anything interesting to report.
Making samples doesn't cover all cases if it not happen each five minutes, what is sort of overkill for the process ( interesting why an interrupt lines invented for computers and other smart machines ? ;)).
One does have to take a small sample to find out the version(s) have changed.
My system is sitting here taking a sample every 5 minutes around the clock. It has nothing else to do unless I am watching tv, which usually occurs at a time when activity is not likely to happen. :)
