I am hoping someone can tell me if I'm on the right track in diagnosing this problem. I recently upgraded my system to a 4DTV DSR-922. This means that I've now go subscription programming and therefore tend to watch more tv instead of just scanning.
Over the past couple of days, I noticed that on the digital channels, they would go black out, pixelate then return to normal. I thought maybe it was not quite peaked, so I went through that process again, and have good signal all across the arc. The next day, it was windy and my system tends to move just a bit (actuator needs replaced when I have some extra $$) so I just let it go. Today is a nice calm day, and it's doing it again.
So I tune over to an analog station, and there's a burst of intereference about every 11 seconds, which you can see on the analog channels. On some of the digital channels, I can only assume this is what's causing the dropout and pixelation at about the same interval.
It's worth noting this only happens during the daytime. I live in the country and my nearest neighbor is about the equivalent of two blocks away. The nearest power line is probably about 1/4 mile away. I believe there is a telephone line that runs about 10 feet away and under the dish.
Now, my LNB and the dish are older (probably circa 1990). I read in a forum where someone posted a setup almost exactly like mine and someone said the LNB would be a bit "noisy" for digital. I believe this one is 30 degree, but the markings are worn off of it. Would a newer LNB possibly end this problem?
I never noticed this before when I would watch analog feeds once in a while during the day on my old receiver. However, the kids are home for summer and it's been hot, so the TV has been on more during the day. My Toshiba TRX 2200 had a "TI Filter" setting which I had turned on, so maybe that's why.
Any thoughts on a possible solution before I try a new LNB?
