If you are are in single mode, you don't need the second remote to stop the recording. As was suggested, use the PIP swap button and flip to the recording channel and press stop or go to the dvr list of recorded shows and the currently recording program will also show. You can access that show and stop from there also. Maybe whoever set up the recording also protected it?How do I stop Recording (while recording) on TV2. I am using VIP722 in single mode (no second tv connected). Search result yeild that second remote can stop it. But installer took sec. remote away since I was not using second tv![]()
1).. the second remote should not have been taken. In single mode with shared view enabled, both remotes control all functions of the receiver.
2) In single mode there really is no difference between tuner 1 or tuner 2, and you can stop the recording either by viewing it or selecting it and hitting the option to stop recording.
3) If you are viewing the channel but not the recording you can get the messages that were mentioned. Find the recording in the schedule and make sure you select it first in that case.
I agree with you on all three points and point three is especially important to note. Good one! I forgot that.
I would definitely call Dish about the Second Remote issue. I was just trying to suggest a solution without getting into the legal issue.
