what components do i need?
bryankaler
6
newbie here.
first, let me explain what i'm needing. i would like to get a tv in three seperate rooms, one in the living room and one in each of my two bedrooms.
secondly, what i have: 322 receiver with separator. a single cable running from my satellite to one of the beadrooms, and a cable connecting the two bedrooms, which i thought i could use the 322 to run both of my bedrooms. i also have a cable running from satellite to the living room, which i tought i could use a single tuner reciver for this room. will this set up work?
lastly, what other commonents do i need? which satellite? what multiswith or splitter for the living room, if any? and what single tuner receiver, 311?
i hope i gave enough info. please let me know if you need more.
any help would be greatly appreciated!
Need more info, little confusing...
You want to be able to watch three separate things at the same time in each of the rooms ?
Or you want the two bedrooms to share the same thing and isolate the living room to watch something different ?
newbie here.
One way of doing it... assuming you have a DPP Twin at your dish.
Get a 311/301 receiver and put that in the living room.
In the bedroom where the SAT line comes in, put the 322 in there. Run a cable from bedroom with 322 to other bedroom OR depending on if everything is prewired and ran to a central location you can get some diplexers.
Here's a diagram.
http://www.solidsignal.tv/dishnetwork/DISH_Pro-DISH_Pro_Plus_Diagrams/DistributionExample7.pdf
Denver Locals HD Problem
Dish DVR 921
