EA is meant ONLY for ViP series receivers. The 625 will NOT work with EA.
Don't sweat it. Unless you're hot for a single dish solution, you may actually be better off with the "old ways."
Gee, I guess it wasn't a coincidence that I got my G3 Purple Cards, huh? Not that I would, but I don't suppose I could swing my Dish 500 around to pick up the 61.5?W/72?W satellites and use my Dish 300 currently @ 61.5?W for 77?W?Scott Greczkowski said:· Transitioning SD-Only Markets –
o South Bend-Elkhart, IN
You likely could do just that. The spacing of the 500 is designed for nine degrees instead of eleven but it would most likely work fine. You would definitely need to adjust the skew.Gee, I guess it wasn't a coincidence that I got my G3 Purple Cards, huh? Not that I would, but I don't suppose I could swing my Dish 500 around to pick up the 61.5?W/72?W satellites and use my Dish 300 currently @ 61.5?W for 77?W?
Bill Millar said:Looking at the uplink report for 09/24/2008, KSWO is on the list, but KHOU is not. I have my Dish pointed at 61.5 and I'll let you know when they show up.
If I had to guess. Waiting for all 4 networks to go HD before we see them. Dishnetwork seems to go in order of market rank and Erie ranks 143 I think. I would hope by the time the snow melts next year they will be up on the Sat and they finally would get rid of listing 35 as channel 5!!! Channel 12 and 24 goes HD OTA 2/17/09 fingers crossed.Erie, PA? Anyone?
Actually you'd just have to get a "wing dish" pointed at 61.5 added on to your existing system. Unfortunately, if they're "splitting" the country, at some place in the country people will have to deal with that problem. Unfortunately for us, we're on the "deal with it" side of the split. Ultimately, hopefully, this will result in more national HD signals, so if that's the case it'll be good in the long run.So does this mean those of us in Omaha have to get a new dish installed to point at the EA in order to get our locals in HD? Are the people at Dish this stupid?
I'm just hoping I can get my 5 week old 1000.2 swapped out for a 1000.4 rather than having a "wing dish", since I meet all of the other criteria needed to be EA (all VIP boxes, no international, etc).
Thanks for the heads up.
However..."KHOU"? I don't know which channel that is for certain. Is it a PBS affiliate or something? The channel 3 NBC station is KFDX. The Fox 18 station is KJTL. KAUZ channel 6 is CBS.
I won't sweat it if E* misses KSWO in Lawton, since I can receive that one in HD over the air. But I would sure like to at least get the Fox and CBS stations to see some NFL games in HD.
Will the HD locals in these new EA markets (Des Moines, in particular) be available for current subscribers on 129? Thanks.
I guess I was editing as you were posting a reply. I assume the same would be true with the 522 (edited post) as with the 625 (erroneous original post).
