I was just given an old Dish 500 that I want to use to pull my HD locals from the 77 sat. This dish has the legacy LNBF with SW21s at each end. Will this work with my 1000.2 or do I need to buy a DPP Dual LNBF and an "I" adapter?
I want the Little Rock HD locals...
I have the same question... to pull in the 77 sat you need the dual DPP LNFB?
Also can I run it through my current switch set-up which is a DishPro 34. I had read that the 1000.4 EA will only work when fed through a DishPro 44.
What gives?
First part is not correct (1k4 have inside DPP switch already), second - yes, DP34 is not DPP switch.Thanks, the earlier post about a DP "Dual" LNFB had me confused.
However, I am pretty certain that in the thread on installing for the Eastern Arc, that any feed from the 1000.4 must go through a 44 model switch and will not work with a 34... that's why I was wondering if I was using a wing dish to catch 77 rather than the 1000.4 if I could just hook it into my 34 switch.
And the smart cards came in the mail a few weeks ago.
ok, simple question in layman's terms. I have a dish 1000.2 with a vip 722 pointing to 110, 119 & 129 and on Turbo HD. If I get 77W on a another dish with a DP (I assume you mean Dish Pro) lnb and then connect to the LNB In port on the 1000.2 dish, will I be able to get Little Rock, AR. HD locals without in other switches or changes? I really don't understand some of the tech talk and not sure if that's all I need to do. Thanks in advance.
