vip722 multiple #2 remotes
jrcdmd
3
Just recently purchased vip722 receiver. Main tv remote is for den tv. Have two other tvs, one in bedroom and one in study, which are connected using signal splitter. Use remote 2 for bedroom tv and purchased second remote 2 for study tv. Did this when using 522 receiver. Found out second remote cannot be programmed to work tv without disrupting function of remote 2 used in bedroom. Any solutions? Thanks.
Where did you buy your second TV2 remote?
Both TV2 remotes should be programmed with same address IR/UHF
Both have the same IR/UHF of 6.3 but use different secondary remote address codes: one uses 2, the other uses 6. Know this by using the sys info button on the receiver. The secondary remote address changes when programming the remote to work with the individual remotes. Is there a way to reprogram secondary remote address? Thanks.
Do you have your user's manual? Page 76-77. It's a little involved. If not, say so.
Had manual. Overlooked this section in trying to find solution (Stupid Me!). Did as manual instructed and works perfectly. Can't thank you enough for helping. Great people like you to help us dummies. Thanks again.
