Trouble with a complicated install
bruckster
2
I am brand new to satellie TV and I am having trouble installing my DirecTV Slimline5 dish with HR-20 receiver.
I live in an apartment complex with stringent rules about dish placement. I don't have a completely clear view of the southern sky, but from what I can tell with my compass, I think the dish should be able to see from 99 degrees through 119 degrees. The edge of my building might just cut off the 119 satelite, but I seem to be getting signals from it.
I live in 30345 - azim 212, elev 47, tilt 67, and in the setup I chose Slimline-5 as my Dish Type and SWM as my Switch Type (am I right?).
I have probably spent an hour pointed at satellite 101 transceiver 1 dithering the azimuth and elevation settings, but I can never get a very strong signal:
56 71 49 56 51 69 47 69
52 71 47 37 55 72 49 71
52 76 50 45 56 72 53 69
54 79 51 55 56 72 51 74
I also dithered the tilt on satellite 119 and this is the best i can get
72 53 69
53 79 50 59 55 72 51 75
Satelite 110:
71 73 39
What's worse, I don't seem to get any signal from 99(c) or 99(s) (what's the difference, anyway?) or on 103(s) or s03(c).
I don't understand why I am failing to get signals from 99 and 103, because as I mentioned, my building is very close to cutting off 119, but 99 and 103 should actually be very clear
My cable run is probably 15 feet and I have checked all of my coax connections. There is a lamp post that is sort of in the line of sight of the dish but it's not dead center and it's about 25 feet away. I got my dish on craigslist, so I don't know for sure if it is any good. Does it sound like possible bad LNBs?
Could a lamp post block out two satellites? What am I doing wrong? What should I do next?
First of all, you need to determine exactly what type of dish you got, and do you actually have a SWM installed because the SWM switch won't work with a standard 5LNB assembly.
Looking at your signal strengths, you appear to have an issue with your odd transponders. Please describe your exact setup, including dish, switch/groundblock, how many cables you ran, and how many you have connected to your receiver, and if you have the BBC's installed.
I had to google SWM, but it looks like that is an external multiswitch? if that's what they mean by SWM, then that is NOT what I have. I ran the setup again with "multiswitch" selected, and I still do not get any signals from either of the 99 satellites.
101 looks about the same as previously posted.
Now I can barely see some (mostly odd) transponders on 103(s):
0 0 33 0 19 0
28 34
0 0 0 36 0 0 29 0
and I can see the odd and some even transponders on 103(c):
15 0 14 0 15 0 13 11
18 14 13 13 17 13
I do not get any signals from 110
I do not get any signals from 119
As for my setup, my dish is a Slimline-5. I need to get a ground block and so I do not have one installed as of now. I have 2 cables running from the switch through BBCs to my HR-20 into "Satellite 1 (FTM)" and "Satellite 2". I also have an HD antenna that is plugged into the "Off-air" input.
Do I need to find a way to ground my system until I get a ground block? My understanding is that the ground was for protection from lightning strikes, etc., but can it affect my signal integrity?
0 0 33 0 19 0
28 34
0 0 0 36 0 0 29 0
18 14 13 13 17 13
Ground block will NOT effect your signal, but don't forget to install one and ground it properly.
Sounds like you do NOT have a SWM set up.
How many rec's are you using ?
The LNB head has a built in MS, you do not need an addl. MS till you get past 4 tuners.
Make sure youn have your BBC's installed.
Are you getting a picture at all ?
IF you cannot get your signal, look in the phone book and see if theres anyone local that can come out and point the dish for you.
Jimbo
Springfield/Holyoke OTA - AM21
UFC on DTV
