Will this Linksys Powerline PLTK300 work with a 722?
John Corn
The Coach / Supporter
1,237
19
North Canton, Ohio.
Just wondering if this will work with my 722?
I have the chance to buy this thing used pretty cheap,
so I though what the heck it might be time to hook my reciever, TV, and blu ray player up to my home network.
From what I can tell it will work, here are the specs.
Features
Use your existing powerlines to network your computers and other devices
Share files, printers, storage, and networked games throughout your home connect it to a router to share your Cable or DSL Internet connection
Easily add more devices to your network by plugging additional adapters into electrical outlets
HomePlug 1.0 with Turbo technology for data rates up to 85Mbps, compatible with HomePlug 1.0
Kit includes one single-port and one four-port adapter
Tech Specs
Model PLTK300
Standards HomePlug 1.0 with Turbo, IEEE 802.3, IEEE 802.3u
Ports PLTE200: Power, Ethernet, PLTS200: Power, Ethernet 1-4
LEDs PLTE200: Power, Powerline, Ethernet, PLTS200: Power, Powerline, Ethernet 1-4
Modulations S upports QAM 256/64/16, DQPSK, DBPSK and ROBO Modulation Schemes
Security Features 56-Bit DES Link Encryption
Security Key Bits 56-Bit Encryption
Dimensions PLTE200: 5.83 x 1.38 x 4.06 (148 x 35 x 103 mm), PLTS200: 5.83" x 1.38" x 4.06" (148 x 35 x 103 mm)
Weight PLTE200: 6.17 oz (175 g), PLTS200: 6.70 oz (190 g)
Power 100-240V AC, 50-60 Hz
Certification FCC, IC, CE, Recycle Logo
Operating Temp. 32 to 104F (0 to 40C)
Storage Temp. -4 to 140F (-20 to 60C)
Operating Humidity 10 to 80% Noncondensing
Storage Humidity 5 to 90% Noncondensing
PC or other device with Ethernet Network Adapter
AC Power Outlet
Powerline Utility Requires PC with CD-ROM Drive Running Windows XP, Vista, or Vista 64-Bit with Latest Updates
Thanks.......:)
Did you know the 722 has HomePlug built into it? I don't see why it wouldn't work with all the items you mentioned. I have my 722 & PS3 connected to this one, NETGEAR XE104 85 Mbps Powerline 4-Port Ethernet Adapter. No problems what so ever. What type of set up do you currently have, or what type of set up are trying to achieve?
I Have a Samsung LN750 LCD, Samsung BluRay 2500, and my 722 I want to hook it to. My main concern was the 722, jus wanted to make sure the specs of the Linksys PLTK 300 would work with the 722. For Example...Adapters
using HomePlug AV, HomePlug 2.0, or a speed rating of 200
Mbps are not compatible with DISH Network receivers.
It should work with the DVD player and TV just fine.
Diplexer Setup
Can I use a SW-21X to add 61.5 to 110/118.7 ?
